JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
AtoZ
Dec 28, 2017Apprentice
Day 3 on hot fix and no trouble so far. The first connection to be kicked off is usually the thermostat. So far, its connected.
tulong
Dec 28, 2017Guide
What's the speed? I tried .20 and my speed has been the worst of all, 14Mps really? the 5Ghz channel is totally hosed and useless. I still have not heard back from Netgear support even with a support case opened for a RMA. Guess I have just wasted over $150 for this useless router which by the way just a little over 3 months old, so screw it Netgear. I am going to flash it with Tomato tomorrow. This will be my last post here. Already advise my friends and co-workers not to buy any Netgear product and I sure will spread the news further. Good luck to the rest of you who are still waiting for Netgear to get their act together.
- LaudekDec 28, 2017Star
As mention on the 9.20 for two hours.
My wired connection was no issue. My android phone 5 Ghz was 866, my android tablet also 5 Ghz upstairs was 760, while my kid's android tablet (5Ghz but about 5 years old) was at ~250. The work-issued Blackberry on 2.4Ghz and only 4 feet away from the router shows a speed of 72 Mbps. My issue is the 2.4 Ghz band dropping. Will monitor.
