JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Beechyboy
Jan 04, 2018Tutor
Just switched to Xwrt-Vortex
http://xvtx.ru/xwrt/download.htm
.... and your problems will be over
KRACK fixed
Firepsych
Jan 04, 2018Aspirant
Hmmm, some newbee questions, if I change firmware to Advanced Tomato or the xwrt (that is the R7000 380.69 version) will I see changes (increase/decrease in speed, signal strength, etc). and I assume that I can switch back to netgear firmware if they get these problems sorted out? I downgraded to 1.0.7.10 (most people went to .12 I see) and seems to be stable. I had 1 problem with a wemo switch losing, then getting back a connection (not sure if it was 2.4 or 5).
