JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
hurricane28
Jan 05, 2018Guide
Hi guys,
Can some of you provide feedback on the new hotfix firmware? I mean, how does it perform and does it fixes all issues?
I ask this as i am still on V1.0.9.14_1.2.25 with no issues and i want to update the firmware savely without any problems.
Thank you in advanced.
AtoZ
Jan 05, 2018Apprentice
hurricane28 Do NOT upgrade. Hotfix doesn't work. Just stay where you are. Netgear is just starting to reach out to users to try and fix the problem. It's going to be a while.
- hurricane28Jan 05, 2018Guide
Okey, thnx for the feed back, will wait for further notice.
