JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 08, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
lepa71
Jan 07, 2018Guide
Bas99 wrote:One of the great benefits with non-Netgear fw is that you get rid of the Disney nonsense as well.
There is also a negative that you are losing hw acceleration. Just saying. I have used them all. There are cons and prons to all of them.
Bas99
Jan 07, 2018Guide
I think you are absolutely right. Maybe the HW accelaration causes this problem? Anyway, this time my network has got an enormous boost when I stopped using Netgears FW.
- lepa71Jan 07, 2018Guide
I think you are absolutely right. Maybe the HW accelaration causes this problem? Anyway, this time my network has got an enormous boost when I stopped using Netgears FW.That is not what I'm saying. 3rd party FWs either have old HW acceleration drivers or none.
