JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
jomihi
Jan 08, 2018Aspirant
Hi all,
reading all this stuff, i did following test: diabling all nice WIFI features like beamforce, auto channel, air time fainess, and did a manual straight forward setting yesterday evening. Till now i have a stable connection on 2.4 GHZ ...... lets see how long this last. However, I hope on an SW update very soon to get the nice things back.
BR
Michael
jomihi
Hi all,
update on prev postings: still stable 2.4 WLAN.
@ Netgear: any offical recommendation what to do? or an actual status from the developers? Pls give us some updates/ timelines.
BR
Michael
- ryanvelliaJan 08, 2018Aspirant
I'm having the same 2.4g/5g problems others are. 5g seems to work fine with most devices but nothing can obtain an IP address on the 2.4g band. This has been happening for some time now and none of the firmware updates seems to fix the issue. I'm running V1.0.9.18_1.2.27 right now.
We shouldn't have to run 3rd party software for the router to do what it's intended to. I know I'll never be purchasing a Netgear router again after this disaster.
- rogier64Jan 09, 2018Luminary
ryanvellia wrote:I'm having the same 2.4g/5g problems others are. 5g seems to work fine with most devices but nothing can obtain an IP address on the 2.4g band. This has been happening for some time now and none of the firmware updates seems to fix the issue. I'm running V1.0.9.18_1.2.27 right now.
I'm quite happy with my R7000, the hardware is fine although somewhat outdated now, but it still does the job well. The firmware however is buggy and luckily there are plenty of alternatives.
