JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Wrocky
Jan 13, 2018Guide
AaronB483 wrote:Just found an article about Google Chromecast and Google Home cause temporarily Wifi dropouts.
This is from an TP-Link engineer. http://www.tp-link.com/us/faq-2050.html.
I don't think this is the issue, but the complaint I read about effects Asus, Linksys, Netgear, TP-Link or Synology.
I came across the article, or certainly similar at: https://www.androidauthority.com/google-home-max-wifi-830129/
which describes a similar issue with the Google Home Max. I wonder how many of us are running Google Home Devices. I am. running a few.
Bas99
Jan 13, 2018Guide
I don’t have Chromecast or Google Home Max; I have a Netgear r7000 and a tp link router. The Netgear has WiFi connection problems but the tp link has not in my configuration. There must be another problem (on top of the problem you describe).
EDIT: after reading more information my conclusion might be not correct: the tp link router affected is the c1200 (I have another type) and a WiFi disconnect can be invoked by a device that is supporting Google Cast (by generating a kind of WiFi packet storm).
- Diggie3Jan 13, 2018LuminaryAaronB483 That is very insightful!
I have Google Home devices AND Android phones on Android 8.1 *AND* recently I was debugging them which involved connecting to them with ADB and dumping the device logs with "adb logcat". I can confirm from what I saw it did look like they were sometimes spewing MDNS messages. If that is exhausting memory on the router it could be the problem. - HWAMJan 13, 2018ApprenticeMy R7000 2.4GHz Wi-Fi dropped when I was away from home. No Google Cast up and running. No Oreo up and running. Just regular devices which were there before the firmware update. The R7000 firmware update did something wrong with our R7000 systems. I don't think we must blame other devices. Nothing changed in my environment, only the R7000 firmware.
- Rikardo007Jan 13, 2018Tutor
Same here. I have 3 kids and a nanny in my house. I have multiple Nexus Players (chromecast built in) for a couple years, 2 standalone chromecasts for 3 years, 2 Brother wireless network printers (3-5 years), 3 iPads, 3 Android tablets, 1 iMac, 3 laptops, 2 smart TVs, 5 smartphones, 2 wireless IP cameras, 1 Ooma Telo2 (wired ethernet to router), and 1 Google home (since November 2017). I've had my R7000 for a couple years now, rarely had to reboot. Everything was working fine until this friggen .18 firmware update. Tried to revert to 1.0.7.12 (reset afterwards and manually entered all settings) and was stable for a few days, but now still dropping multiple times a day. I do have 4 separate SSIDs (one for each 2.4G and 5G main and guest), no QOS.
I'm one of those "if it ain't broke, then don't fix it". The only reason why I did the update was because I was about to add a HDD to the router (did not connect it yet) and I noticed there was a firmware update. I hadn't updated the firmware since I first set it up and I remember getting a couple emails from NG in the past year regarding security patches. What a mistake.
HWAM wrote:
My R7000 2.4GHz Wi-Fi dropped when I was away from home. No Google Cast up and running. No Oreo up and running. Just regular devices which were there before the firmware update. The R7000 firmware update did something wrong with our R7000 systems. I don't think we must blame other devices. Nothing changed in my environment, only the R7000 firmware. - LucidInsanityJan 13, 2018Initiate
Same issue here. All these disconnects started after the lastest fimware update. Was running flawless for over a year with 0 issues until this update.
- Rikardo007Jan 14, 2018TutorWhile they claim that is an issue, i have 2 Nexus players and an Galaxy S8 on Oreo and my setup was running fine for months until i updated to the .18 firmware.
- Rikardo007Jan 14, 2018TutorI did read the article. While there may be issues related to some Google products, i did not experience any problems for months until i updated the firmware on the R7000 to .18. I've had my S8 since May and Nexus Players updated to Oreo approx Sept 2017. My issues began within hours of the NG firmware update.
- AmloddJan 14, 2018Aspirant
Whilst there are many references to using Google products and Android etc, I have none of these and can confirm that the issues highlighted in this (and other) threads only became apparent 'immedeatly' following the update to the latest version of the firmware. Not only on the R7000 router that is some years old, but on an R7800 router to which I ugraded the firmware straight out of the box.
Whilst the problem may be exagerated by Google, or other products, for me, it is clearly related to the NetGear firmware change - unless we want to start introducing Apple and Synology products to the mix as well.
- Diggie3Jan 14, 2018LuminaryTo save new people reading dozens of pages, if you want to stick with stock FW instead of Vortex or Tomato until NG puts out a fixed version nearly everyone has stability going back to 1.0.7.12 (March 2017), and some as far up as 1.0.9.6, but generally not after that. If you want 1.0.9.6 you will also have to turn off automatic updates after installing it.
- rogier64Jan 14, 2018Luminary
Diggie3 wrote:
To save new people reading dozens of pages, if you want to stick with stock FW instead of Vortex or Tomato until NG puts out a fixed version nearly everyone has stability going back to 1.0.7.12 (March 2017), and some as far up as 1.0.9.6, but generally not after that. If you want 1.0.9.6 you will also have to turn off automatic updates after installing it.About 8 months ago my R7000 became unstable after a firmware upgrade. I never got it stable again, even returning to an old firmware. But test it yourself. I tried different alternative firmware versions and found XWRT-Vortex the best there is if you also want security patches.
- potamus29Jan 14, 2018Guide
I rolled back to FW version 1.0.9.10_1.2.21 five days ago, still ok, no drops.
