JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Robb_H
Jan 13, 2018Tutor
Experiencing the same problem as most others seem to have -- unreliable connections on 2.4 GHz after "upgrading" to this version. I've seen a lot of praise for XWRT-Vortex, but after doing some background research, it seems that the source code for the modifications to the XWRT-Merlin code base had not been released to the public. That makes me very reluctant to install it.
What other options are available? I see a few references to different versions of Tomato. I've used dd-wrt in the past, but it seems to have fallen into disfavor. Any recommendations for something that works and is truly open source?
AtoZ
Jan 13, 2018Apprentice
And people wonder why we get frustrated. Can anyone give me a good reason why the most recent folks on these boards were still directed to do a firmware upgrade with something that doesnt work? This makes no sense netgear! Pull the damn updates down and hide them. No one should be upgrading their routers! Smh
