JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Junopapa
Jan 20, 2018Tutor
Diggie3 wrote:
Really... 713 posts on the topic in this thread alone, and that's what you're going to ask?
You are fair to say this but, I was reading about wireless drop-off complaints. Before I continued to read another 700 posts on the same topic, I posted about internet connectivity. I'm seeing strong wifi signal but my Netgear CM500 modem is dropping intermittantly after the 1.0.9.18 update this morning. I was thinking a different issue. The problem is corrected by re-booting the modem and not the router.
rogier64
Jan 20, 2018Luminary
Junopapa wrote:
Diggie3 wrote:
Really... 713 posts on the topic in this thread alone, and that's what you're going to ask?You are fair to say this but, I was reading about wireless drop-off complaints. Before I continued to read another 700 posts on the same topic, I posted about internet connectivity. I'm seeing strong wifi signal but my Netgear CM500 modem is dropping intermittantly after the 1.0.9.18 update this morning. I was thinking a different issue. The problem is corrected by re-booting the modem and not the router.
Dropping and reconnecting WAN to LAN is also one of the issues caused by the latest firmware as well as a spontaneous reboot of the router.
