JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
potamus29
Feb 09, 2018Guide
1. Many of you seem to have updated to the latest beta and still experience the issue. Is this true? -Many users have confirmed that the issue has been fix with the latest hotfix. You have to check as well if you have google home devices or chromecast or any other device the uses casts feature that contributes to the issue. There is a known issue with those devices.
The hotfix is by no means a complete solution as evidenced by those with continuing problems. I used screen cast on an earlier firmware without problems. It's Netgear that has the problem, trying to pass it to others is pretty poor.
2. I don’t like betas and am scared to move off of 1.07 for fear the issue will come back with the latest release. - This is considered as official firmware since it is released in official website.
If it is considered official firmware why does the broken 1.0.9.18 remain as the first download available?
3. I am unclear what risks and security holes exist in 1.07 and am worried about being on this old version too long. - Then you might have to consider upgrading to the latest firmware. Please take note that not all users have the same environment and network setup.
Or you may consider moving to a third party frimware that does not have the issues provided by Netgear
4. I have seen nothing from netgear that officially admits to the problem, explains the root cause, and communicates to all of us when an official fully 100% tested release will be available. - It has been confirmed by NETGEAR that it is an issue that is why the firmware was released.
Has it been admitted by Netgear that they have not completely fixed the problem, because they can't find what they did to break it? I've seen no explanatory communication from them, has anyone? An apology would be a start.
ddurig
Feb 09, 2018Guide
I have in fact seen the opposite from netgear. Rather than admit fault they blamed Google. They released firmware that caused the problem for me. While I have Google products I had no problems until I upgraded and then I could not make it more than a few hours.
I downgraded after trying the betas and still having the problem. Granted I did have an issue a few times after downgrading (twice in two weeks) it was not every few hours like I was seeing. I believe the continued issues were based on the Google products because after updates were released I have been stable again on old firmware. Since I am not paid to be a beta tester I bought a new router, not netgear sadly, but it seems this has spread to other devices of theirs as well so I am now out.
I also have issues that the problematic firmware continues to be posted with no warning or updates and this is not an acceptable practice to me as I work in the wireless industry and if we did this it would be in the news. Communication from netgear is poor. I have seen a few posts from them that you need to hunt for but nothing on their support pages press releases and they continue to act as if this should be business as usual.
- hurricane28Feb 09, 2018Guide
Do you know how many people i meet online that claim to work as or Engineers or "in the industry" ?
I mean, if you are really an professional you have other ways of contacting Netgear instead of posting on forums...
You can call them, email them and send PM via this website.. I had a problem once with my router to witsh i called them and they solved it pretty fast via Email.
Anyway, as to the problem, this is greatly caused by Google devices. Its not only Netgear but TP-Link, Asus they are all affected by it and Google released an update to fix this issue. Even without using the Chromecast it can cause issues as you have to reset your hole network in order to get rid of it. Even resetting the router and or the modem is needed. This is where factory reset is made for.
On another note, what did you expect from Netgear? That they simple come here to argue with people and take the **bleep** from people who have no idea what they are doing and blaming Netgear for it? I mean, did you read the comments that some people wrote here? That wouldn't be very professional imo. Instead they are working on a fix which worked for many users.
- potamus29Feb 09, 2018Guide
Hi Hurricane28, interested in your comments, work for Netgear do you?
I contacted Netgear regarding the problems that I experienced before I found this forum. I have found more support and information here than I received from Netgear, which was precisely zero.
The problems were not caused by Google devices in my case as I don't have any and after performing all available checks and resets the solutions were to revert to an earlier release, instal third party firmware or say goodbye to the Netgear router.
I initially reverted to an earlier release which worked, but obviously there could be security issues, so rather than dump a reasonable piece of hardware decided to install other firmware, went for XWRT-Vortex.
What do people expect from Netgear?, feedback, you know, simple communication. If they had they would have prevented a large number of people from losing faith in them as a company and buying from their competitors. I also think they should remove the faulty firmware release from their website.
I suggest you read a few more of the posts before trying to exonerate Netgear from blame.
Not everyone is as expert as you think you are.
