JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
mzguy
Feb 13, 2018Apprentice
Case850 : HWAM is right. You continue to ignore the facts that you continue to ignore while you criticize others and try to shift blame away from Netgear. Why? Do you work for Netgear?
If you don't work for Netgear, why do you mislead others and shift blame away from Netgear? Both I and HWAM have technical backgrounds. And besides, the logic is simple:
1. Those without Google Cast devices have this issue.
2. The disconnects due to Netgear started with a firmware upgrade for many, not with a Cast installation.
3. Netgear admits problems beyond Google-caused ones. Why don't you?
- mzguyFeb 13, 2018Apprentice
OK... my last post disappeared after I was told it was awaiting approval. In it I recommended a product that does not have issues like Netgear does.
Is that why my post is gone? Did anyone subscribed to this topic receive it via email so I can re-post? If so, please direct message me. Thanks.
