JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
shadowsports
Feb 19, 2018Hero
LM22wrote:I was having 5ghz disconnects daily with firmware 1.0.9.18. I turned off the 5ghz guest network and every single problem disappeared. Just wondering if anyone can attest to the stability of 1.0.9.26?
You and me both. I noticed the beta was pulled a while back. Haven't seen anyone mention results after installing the final release.
Roomie
Feb 19, 2018Tutor
i´m on 1.0.9.26 and having absolutley no problems, 11 days up without reboot.
wifi: 2 samsung tv´s, android tablet and mobile, raspberry pi - all on 2,4 ghz, win10 laptop (5 ghz)
lan: dlink nas, 2 raspberrys, denon network av receiver
guest wifi 2,4 ghz activated for guests
- MetzrothFeb 21, 2018Aspirant
I had to roll back to 1.0.9.18 because 26 completely broke my 5Ghz network for my lightswitch and on my iPad made the speed go from 50Mbps to 5Mbps. Downgrade fixed all. 2.4Ghz was unaffected.
