rsarvie
Apr 04, 2018Initiate
Firmware V1.0.1.44_10.0.44 tanked my 2.4GHZ Speed
Recently updated my R6700 to Firmware V1.0.1.44_10.0.44. First had to reset both modem and router multiple times as I had the "Your computer appears to be correctly configured, but the device or reso...
- May 27, 2018
Hi All,
Please try the new firmware.
https://kb.netgear.com/000058220/R6700-Firmware-Version-1-0-1-46
bugmenot2
Apr 19, 2018Apprentice
Thank you!!!
It also dropped all of my 2.4GHZ devices. A reboot of the router would show them for a few seconds under the 'connected devices' but a single refresh of that and they were gone. I tried every which way, including enabling a brand new 2.4 ghz guest network, nothing would ever connect (I have five devices - thermostat, wifi plugs, lights, etc.) All of them fell off with the upgrade, so it's definitely not a device issue. Reverting as you suggested fixed everything - all five devices came right back on without me needing to do anything to those devices.
JamesGL
May 27, 2018NETGEAR Employee Retired
Hi All,
