DKern
May 31, 2019Tutor
How do I stay logged in?
Every time I open the browser on my desktop I have to log in to the router. Is there a setting to keep it logged in?
- Jun 02, 2019
IrvSp.... I cleared the cache and restarted the computer. That worked!! Thank you so much!
And thank you to everyone else for hanging in there with me and trying to help! I really appreciate it!
For some that were wondering: I wasn't directed to go to the Netgear Account sign in page. I found that to be the only page I could get to. And then I could go anywhere from there after signing in again.
Thanks again everyone!
DKern
Jun 01, 2019Tutor
Im the owner of the router. I'm at home. It's wired to the computer. Hooked to a Cisco DPC3008 modem from Charter/Spectrum.
DKern
Jun 01, 2019Tutor
My homepage is my.yahoo.com
Windows 10 Home Version 1803
Microsoft Edge
Netgear Nighthawk R6700v3
My homepage will load. Then I have to go to a Netgear Account page to sign in. It's actually the page that I had to register my router on. It says 'Log in to your account'. I log in, then I can go wherever I want (surf the web).
The page I have to go to is netgear.com/success/r6700v3aspx?sn=58Y58B76A39E3
- michaelkenwardJun 02, 2019Guru - Experienced User
Can you explain this bit:
Why do you have to go to a Netgear Account page if your homepage has loaded?
Do you get directed to the Netgear page?
It sounds more like something strange going on in your browser than anything Netgear is forcing on you.
Have you tried using a different browser?
What is the address of the page that throws up this message?
What says login to your account?
- IrvSpJun 02, 2019Master
DKern wrote:My homepage is my.yahoo.com
Microsoft Edge
Very odd?
Let me see if I get this right? These are the steps:
- Your computer is on as is your router and your PC is connected to the router.
- You open Edge.
- Your home page on Edge, my.yahoo.com, loads.
- You HAVE to go to a Netgear page and login.
- Only then can you use the Internet to browse sites.
Simple set of questions now:
- On step #3 above, what is IN the URL of Edge?
- If on step #3 you enter in the URL of Edge www.cnn.com, what happens (clearing whatever might be in the URL)?
- On Edge, did you ever clear the Browsing Data (see screenshot on left, select the 3 dots on right, then Settings, then 'gear' and clear all data) and try again.
Funny, "netgear.com/success/r6700v3aspx?sn=58Y58B76A39E3" doesn't work for me, says page not found? Suspect it is cached on your PC, hence the last question.
You still have Internet Explorer installed in W10. Using the WINDOWS KEY+R, enter 'iexplore' into the command prompt and that will bring up IE. Does the Internet work and can you browse with that without having to go to Netgear and login?
- DKernJun 02, 2019Tutor
Excellent news. SOLVED.
Trying a different browser, another idea from IrvSp, should have had the same effect.
