gobananasnet
Oct 12, 2021Apprentice
How do you update the RBS750 Satellite firmware from the Orbi app?
How do you update the RBS750 Satellite firmware from the app (NOT the web portal 192.168.1.1)? The router is an easy process, but not the satellite. Thanks
- Oct 16, 2021
Try admin and password?
Oct 13, 2021Guru - Experienced User
Is .1.2 the IP address of the RBS your trying to access or the RBR? RBR is usually .1.1
If the RBS try using admin and password. However it should be same as what you applied on the RBR.
Please use the Choose File button to attached picture files to. Otherwise we have to wait for moderators to approve pictures.
gobananasnet
Oct 15, 2021Apprentice
Yes, I'm aware of that. But it is trying to access 1.2 as shown below. Not sure if the screen shot loaded or not. Tried three times. Ugh!
- plemansOct 16, 2021Guru - Experienced User
the username/password for the satellite should be the same as the one to log into the router.
- gobananasnetOct 16, 2021Apprentice
Yes, I've tried that, yet nothing happens. I click the button and the two fields go empty and no error message or anything. Nothing happens. Ugh!
- FURRYe38Oct 16, 2021Guru - Experienced User
