VJOGuy
Feb 26, 2022Aspirant
Internet signal cutting in/out
Hi there, Keeping in mind that anyone reading this is very likely to be more educated about routers than I am (so please be patient with me), I have the following issue. I've had my R8000 rou...
- Feb 26, 2022
Your modem already has a built in router and wifi. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setupIf you can't bridge the mode, try option #2...
Feb 27, 2022Guru - Experienced User
Give the DMZ suggestion a try first before trying something different. The DMZ option should work for you...
VJOGuy
Feb 27, 2022Aspirant
Thanks! Still trying to figure out how to accomplish that. It seems that T Mobile has blocked a lot of this modem/router's capabilities, from what I'm reading. But I'm still on it. Thanks again!!
- FURRYe38Feb 27, 2022Guru - Experienced User
If you can't seem to find the DMZ or IP-Pass thru featured on the ISP Modem, you can try the AP mode suggestion of course.
