MarcDiller
Mar 22, 2025Aspirant
Re: Invalid Access from Source, WIFI goes down
I am getting similar messages, except when I get the message, WIFI goes down. The MAC below (obscured last numbers) is the MAC of my router. Firmware: v1.3.3.152 What does this mean, how do I a...
Mar 27, 2025Guru - Experienced User
Do you have access controls enable on the router?
What is the device with the MAC Address using 3C:37:86:xx:xx:xx ?
- MarcDillerMar 27, 2025Aspirant
It's the Netgear. 192.168.1.1 is my default gateway to the Netgear:
Arp -a (from desktop)
Internet Address Physical Address Type
192.168.1.1 3c-37-86-f7-31-46 dynamicNo devices are blocked:
Thanks,
- FURRYe38Mar 27, 2025Guru - Experienced User
Does this happen if you disable Access Control?
- MarcDillerMar 28, 2025Aspirant
I disabled access control, will see if it happens again.
Thanks,
