JmJacob's avatar
JmJacob
Tutor
Jun 27, 2016
LED lights not working
I just set up my new Netgear R7800 as an access point, and it works completely fine, however, the all of the LED lights are off appart from the power LED.  I know there is an option to turn them off/...
  • VE6CGX's avatar
    VE6CGX
    Jun 27, 2016
    That must be wish, in my experience with many different router from different vendor during review and testing time, I don't recall
    such feature. I guess f/w can do such thing but personally that is low priority item among many issues to deal with. In my case if
    I wanted something like that I'd attach some jury rigged circuit to the router to control the lights any way I want. You can make a
    fearue request to NG, I guess.
