pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
schumaku
Apr 03, 2018Guru - Experienced User
martijn76wrote:Hasn't this been solved by the latest 1.0.2.46 firmware? Haven't installed it yet, but the changelog does say:
New Features and Enhancements: Supports the VPN client feature.And this would suggest a fix in the VPN department.
This "VPN Client" is a new feature for your router model: It does allow to initialise a VPN connection from the router ie. to your office or to a hide-my-a** VPN server.
Diggie3
Apr 03, 2018Luminary
It's probably best for end users if the generation is supported on the device directly, but could be accelerated by genie if it was available. It's the dh-param that is slow and in fact worst case they could keep the one the unit shipped with, even though it's too short IMO, and at least regenerate certificates that didn't have md5 digests. This would be a fairly fast operation.
However, if I was in the web interface and it said, "Are you sure you want to continue? Generating new certificates and parameters could take up to an hour and router performance may be slower during that time", I would be fine with it. Who wouldn't rather do that than pull out a laptop and do it all manually? Just run it before bed.
