pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
JamesGL
May 03, 2018NETGEAR Employee Retired
Hi All,
The firmware is for R7000 only. We will provide update once firmwares are available for other models.
jcw265
May 04, 2018Tutor
So is it Netgears superior wisdom to decide what model gets the VPN fix o ver other customers with different models. Man it’s time for a BBB report on this total customer neglect. So when will u allow the owners of the R7800 to get the VPN access your product states it supports. You only hot fix one model. Wow. Sorry excuse for a so called main line company. Supply the fix for all the models you broke from your neglect. Might make a nice class Action suit actually.
- tonyGasproMay 04, 2018Guide
I may just take mine back to Costco, state the reason why (that it now doesn't perform per the specifications listed on the package) and replace with with another router.
I am sure they (Costco) would like a word with Netgear why they are selling a product that has fraudulent specifications listed on the packaging.
- MulversMay 14, 2018Initiate
I’ve had to download an old version of OpenVPN for this to continue working. Putting me and my data at risk. Think I like others are going to return the router claiming it’s faulty and buy another brand.
when is this going to be fixed? All those promised dates have been and (long) gone
