cltejensen's avatar
cltejensen
Follower
Jan 19, 2016
Misfortune Cookie for AC1900 R7000 with firmware v1.4.4.30
Is the firmware level vulnerable to the Fortune Cookie hack? If so is there a more recent version of the firmware that resolves the issue?
  • dvinell's avatar
    dvinell
    Jan 24, 2016
    I think it's fairly standard for companies to be blind-sided by vulnerability reports from third party researchers, but that's not to say that they don't do their own internal testing as well.
    However, Netgear don't use RomPager, and aren't "on the list" as far as CheckPoint are concerned.
    I'd also keep remote management turned "off" to be safer.
    http://mis.fortunecook.ie/misfortune-cookie-suspected-vulnerable.pdf
