Lionhawk
Aug 16, 2021Star
Modem & Router with Xfinity issue Drop in speeds
Hello all, I am pretty much a novice when it comes to setup beyond the basic stuff. I have Xfinity 1200 mbps and using the below equipment: Modem: Netgear CM1150V Router: Netgear Nighthawk R70...
Aug 18, 2021Guru - Experienced User
go to 192.168.100.1
antinode
Aug 18, 2021Guru
> [...] I can't seem to get to the routerlogin.net page
"seem"? When you do _what_, exactly?
A vague description of what does _not_ happen is less useful than a
clear description of what _does_ happen.
"can't" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read?
> go to 192.168.100.1
Why? That'd be the DOCSIS modem, not the router.
