JFII
Oct 14, 2021Guide
Mounting the USB thumb Modify stock FW?
The r8500 does not auto mount or remount a usb device when it is restarted. Within the remote console how does one force the mounting of the thumbdrive? I tried hotplug Then is there a way to scri...
michaelkenward
Oct 15, 2021Guru - Experienced User
What are you "restarting"? The router? Something else?
Do you mean reinserting the USB device? (What is that device?)
If so, it does here. But have a different router.
What firmware do you have on your R8500?
JFII wrote:
Just answer once you stop laughing. (between thisn and no local lan name reolution, kind of says a lot about netgear)
What does that mean? Again, no problem here.
JFII
Mar 27, 2022Guide
Firmware Version
V1.0.2.154
Sorry for the late response
When rebooting the R8500 (power off or via interface) with a Samsung, PNY or SNADISK USB - 3.0 64GB, 128GB or 256GB chip inserted and mounted using and configured as a ready share device. When the R8500 comes back up the device is no longer mount nor is is available to be mounted. I need to physically remove the device from the R8500's USB port and plug it back in before it is recognized. I might accept that I would need to remount it through the UI but the R8500 will not recognize the inserted thumb drive until I remove and reinsert it.
MY R7500 would always automatically remount a thumb drive and be ready for use without any intervention
