MasterSleep
Feb 18, 2021Aspirant
My R8000p is having issues with the 5G-1 band
So I Got A New Router The Nighthawk 6s (R8000P) and It Worked Like A Charm For The First Few Weeks. Then Recently The 5G-1 band Starts Disappearing And When I Try To Connect On My Phone It Just Says ...
Feb 18, 2021Guru - Experienced User
What firmware version are you on?
MasterSleep
Feb 19, 2021Aspirant
I am on version v1.4.1.68_1.3.28
- plemansFeb 20, 2021Guru - Experienced User
some of the R8000P's stuggled with netgear armor for some reason.
Try installing verson 1.4.1.42. Install it over a hardwired connection, then do a factory reset, and new install. Don't install from a backup.
Then disable auto-updates and try it for a bit of time.
