ifixidevices
May 09, 2016Luminary
need r8500 Power adapter replacement
Hi guys, Unfortunately my puppy decided to get into my computer room and cause havoc with power cords (didn't get hurt thankfully but he decided to start chewing on the large parts of the adapter...
- May 09, 2016
ifixidevices Since E-bay is a non-authorized reseller, consider buying a new power adapter.
Its part number is 332-10631-01.
ElaineM
May 09, 2016NETGEAR Employee Retired
Hi ifixidevices
Welcome to the community!
Kindly register your NETGEAR router and PM me your proof of purchase to move forward.
Thank you!
ifixidevices
Thanks ElaineM, I bought it second hand off of eBay (I've bought a lot of netgear products that way.) It says it's already registered. Can I still PM you with the serial number of the unit or am I SOL?
