ifixidevices
May 09, 2016Luminary
need r8500 Power adapter replacement
Hi guys, Unfortunately my puppy decided to get into my computer room and cause havoc with power cords (didn't get hurt thankfully but he decided to start chewing on the large parts of the adapter...
- May 09, 2016
ifixidevices Since E-bay is a non-authorized reseller, consider buying a new power adapter.
Its part number is 332-10631-01.
ElaineM
May 11, 2016NETGEAR Employee Retired
ifixidevices I apologize but there's no option to buy a power adapter directly from us.
Your best option is to look in stores for the generic adapter that has the correct voltage specs.
ifixidevices
May 11, 2016Luminary
It's alright... I managed to find a china seller so I'll have to wait but fortunately I have another router I can use in the meantime.
I appreciate your help :)
- ElaineMMay 11, 2016NETGEAR Employee Retired
You're welcome! Hope you'll get it up and running soon.
