LOISLANE
Aug 05, 2020Initiate
Netgear Nighthawk R8000P Firmware Update
Firmware not updating manually nor via router web check option. Nighthawk R8000P Current Firmware Version: 1.4.1.50 Update Firmware Version: 1.4.1.62 I have attempted to update the firmware via the Ro...
- Sep 23, 2021
I also was unable to update router firmware with the Nighthawk App, it would go for about 2 minutes, then fail, saying to "Try Again" later, which never worked. But it succeeded when I used a browser (FireFox) to 192.168.1.1 and chased it down that way.
shadowsports
Aug 18, 2020Hero
AndreCarraretto wrote:I was able to upgrade normally as I had already moved from 1.4.1.50 -> 1.4.1.56 (beta). From 1.4.1.56 to 1.4.1.62 was a normal (no errors) upgrade.
Same for me as you already know.
shadowsports
Aug 19, 2020Hero
I've escalated this topic to the moderators for investigation.
- DR650SESep 15, 2020Guide
This is such garbage on Netgears behalf. Why is this problem not solved and Why has Netgear refused to comment? The current firmware cuts my speed in HALF from what I should be getting and has serious QoS issues!
- malssidOct 14, 2020Star
Problem STILL not solved. Honestly **bleep** netgear and their **bleep** customer support. I can't update manually or automatically to the latest firmware. My router is bricked.
