LOISLANE
Aug 06, 2020Initiate
Netgear Nighthawk R8000P Firmware Update
Firmware not updating manually nor via router web check option. Nighthawk R8000P Current Firmware Version: 1.4.1.50 Update Firmware Version: 1.4.1.62 I have attempted to update the firmware via the Ro...
- Sep 23, 2021
I also was unable to update router firmware with the Nighthawk App, it would go for about 2 minutes, then fail, saying to "Try Again" later, which never worked. But it succeeded when I used a browser (FireFox) to 192.168.1.1 and chased it down that way.
Noob1949
Nov 02, 2020Aspirant
Yes, I restored factory defaults and set it up all over again. That is when I discovered it would not update the firmware.
Dezldad
Nov 29, 2020Aspirant
So for those of us outside the 90 day warranty period (I'm +-120 days), is our only option to buy a new router? Has anyone outside the warranty period successfully gotten any help from Netgear?
- ravenskieDec 27, 2020Aspirant
Having the same firmware upgrade problem on my Nighthawk R8000P as others reporting. Trying to upgrade from 1.4.1.50 -> 1.4.1.66_1.3.26
Continues to show my current firmware version as V1.4.1.50_1.3.10
Any ideas on how to fix this? Not super excited about running on a firmware version with a know security vulnerability. I had the same problem one person reported where my router stopped working and all the admin passwords got reset, like it had been factory reset. At that point I couldn't do anything with it so I factory reset it manually and thats how I ended up here.
