Swindonpete
Nov 23, 2020Guide
Netgear Nighthawk X6 AC2200 Tri-Band Wi-Fi Extender and BT Broadband
Hi All - Could anyone help me - I've got a BT broadband connection with their latest router and I'm looking to buy a Netgear Nighthawk X6 AC2200 Tri-Band Wi-Fi Extender Can anyone confirm it will ...
Nov 23, 2020Guru - Experienced User
It *should* work. Just don't use WPS to set it up.
I say should because ISP supplied routers aren't known to be that great at playing well with others.
Swindonpete
Nov 23, 2020Guide
Thanks very much. Is there a simple guide to the setting up steps without using WPS please?
- plemansNov 23, 2020Guru - Experienced User
there's guides and even a video on the support site. I think its the 4th video on the support site. it says how to setup using installation assistant.
https://www.netgear.com/support/product/EX7700
- SwindonpeteNov 23, 2020Guide
Great - thanks very much for this help tonight. Much appreciated.
- michaelkenwardNov 24, 2020Guru - Experienced User
BT likes to lock its modem/routers into router mode, no option for modem only.
Some users resort to using a second router in AP mode, while others bin their HomeHub and get something more capable and controllable.
