MachineDoctor's avatar
Feb 26, 2020
NETGEAR Nighthawk X6 Smart WiFi Router (R8000) - AC3200
I purchased this router and really like it. However I have a shop that is a bit far from the house to get signal. It is close enough tho to wire it. Would an acess point hooked to my router be my bes...
  • plemans's avatar
    Feb 27, 2020
    If you have the option to run a wire to a shop and connect a device there in access point mode, that will be your best bet. You're correct in that.
    How far it it? You can usually run ethernet 300ft.
