Morganino
Jun 26, 2017Tutor
Netgear R7000 and OpenVPN for Android App
Hi, since last OpenVPN for Android App update (v.0.6.73) downloadable at the following link: https://play.google.com/store/apps/details?id=de.blinkt.openvpn OpenSSL version was upgraded to 1.1 and...
- Feb 28, 2018
Thanks everyone for feedback so far. Attached is version 1.0.1. I fixed some typos, added a suggestion to clean up your tftp folder when you're done, and made a note about the OpenVPN version that's most compatible with the document.
Some users looking to work through this doc may find that they can avoid Step 1 by visiting this hidden page:
If the debug page loads and there is an "Enable Telnet" option then you got lucky. Note that either the debug page or the option to "Enable Telnet" may not exist on your device or firmware version. Remember to check that this option is disabled after you're finished because having telnet enabled is a security risk.
katsaw
May 01, 2018Guide
pthorvald wrote:
First: A thanks to NG for comming through with a fix.
> Does that mean the new certificate must be generated after firmware upgrade?
I have not tried the fix yet. However, my guess after the update we will have to export the keys and deploy them to our devices just like we did originally.
If anyone gets a chance to look under the covers of what they implimented I would be interested in learning what you find. (I won't be able to look for a week or so) I am guessing they are using the same keys for everyone (just like before). Consequently I am hoping I can go back in and put the keys that Diggie3 showed us how to generate back in. (This will also save me from having to distribute keys again)
I am afraid that Diggie3‘s method no longer valid after this new firmware upgrade. I hope somebody can tell if Diggie’s method can still work with this new firmware version.
Diggie3
May 01, 2018Luminary
Hi all,
Unfortunately I have been absolutely slammed with work for some time, working nights and weekends, and I haven't had a chance to work on the VPN issue lately. I am glad people were able to update their certs and help one another around some issues.
I don't expect to be able to try the beta before the weekend at least. Just putting that out there in case anyone was waiting for a comment from me.
