malacath's avatar
malacath
Netgear R7000 IPv6 ICMP Filtered
When going to http://ipv6-test.com/   The test only gives my 17/20   The reason is that ICMP is filtered which according to that site is a bad thing.   I know it is definately the router doing ...
  • TheEther's avatar
    Apr 29, 2017
    malacath wrote:
    Is this website correct?
    Yes.
    Is filtering ICMP really a problem?
    Will it cause problems when websites start going ipv6 only?
    It can be a problem.  IPv6 relies on something calling PMTUD (Path MTU Discovery) to work.  Blocking ICMPv6 prevents PMTUD from working.  Unfortunately, unblocking ICMPv6 has a downside.  It can expose your devices to a certain kind of DoS attack (atomic fragment attack).  This puts you in a "Damned if you do.  Damned if you don't." situation.  There is work ongoing in the IETF (the standards group for TCP/IP Protocols) to figure out how to fix this.
    In the meantime, you may find that things will work even without ICMPv6.  Consider yourself lucky.
