duncanc93
Feb 19, 2018Tutor
Netgear R7000 nighthawk settings for xbox 1 x
 So im super new to this and i am just trying to figure out the best possible settings for my xbox one x (currently using wifi for now)     Im slowing learning what this QoS is for and port forwarding...
- Feb 20, 2018
Well i ended up just factory resetting the router and now im getting around 230-240 mbps on both, latency is around 50-60 which i wish i could get a little lower, i think i might of messed up something in the QoS setup
duncanc93
Feb 20, 2018Tutor
XRaptor29
Feb 20, 2018Luminary
I just replaced my R7000 with a XR500 because it kept dogging the wifi down after a few days even on the latest firmware, Wired was perfectly fine though. Rebooting the router would fix it temporarily.
Now my issues are gone with the XR500.
- FURRYe38Feb 20, 2018Guru - Experienced User
Enjoy.
