DanDel
Dec 28, 2020Aspirant
Netgear R7000 won't update firmware
My R7000 won't upgrade the firmware from V1.0.9.88_10.2.88. I go through the procedure on the app, but it always comes up with "No new firmware is available at this time." I got an email in August sa...
- Dec 29, 2020
DanDel wrote:My R7000 won't upgrade the firmware from V1.0.9.88_10.2.88. I go through the procedure on the app, but it always comes up with "No new firmware is available at this time." I got an email in August saying the firmware should be updated to version V1.0.11.106. I have not been able to perform the upgrade since then. I just got a new email saying it should be updated again. Still won't update.
Your signature states you have a R7000P AC2300. If that is the case, you won't get far with the firmware you're trying to download because the firmwares you have mentioned, are for the R7000 AC1900. So which router have you got?
Even then, if you have got the AC1900 version, the latest firmware is v.110
Furthermore, if you are one of the unfortunate AC1900 owners who claim their router wi-fi drops out all the time for no apparent reason, then the standard line thrown out on this forum is, downgrade to v.42. Bear in mind if you follow that advice, although your router might be more 'stable' insofar as the wi-fi not dropping, it's a 3 year old fimrware that may or may not be full of security holes. You take your chances on that one. But then Netgear make all their previous downloads available to allow folks to roll back if they choose to and yet the very purpose of firmware upgrades, is to fix/plug security and functionality issues. It seems some routers don't handle some of these 'upgrades' too well.
You don't appear to be the only router owner who is getting confused with model numbers and firmwares.
Portwey84
Dec 29, 2020Virtuoso
