Mengele63
Jan 04, 2025Aspirant
Netgear R7000p change region
Who will tell you how to change the region in the router settings. The default is North America on a gray background.
- Jan 04, 2025Where did you buy this router from?
Mengele63
November 2024 from Ebay
microchip8
Jan 04, 2025Master
Looks like you got a US version. You can't just change regions willingly. There are regulations for different continents.
- Mengele63Jan 04, 2025AspirantI don't think so, I have another router of the same type, bought on Ebay, and it somehow switched to the Europe region.
- michaelkenwardJan 05, 2025Guru - Experienced User
Mengele63 wrote:
I don't think so, I have another router of the same type, bought on Ebay, and it somehow switched to the Europe region.I'm afraid that that does not prove anything. microchip8 may be spot on. Routers sold outside North America do not have the same "lock".
If the other router have arrived originally had European settings that someone set to "NAS", that would not prevent a later switch back to another region. If you have one that arrived locked to NAS, you are stuck.
This used to work on some routers:
Solved: WNDR3700v2 (N600) - Can't change wifi region - NETGEAR Communities
Unlike the R7XXX generation, newer routers don't even have an option to "move" them to NAS.
Just another user with time on their hands.
