paillassou
Nov 05, 2020Apprentice
Netgear R7800 Firmware 1.0.2.76
2020/04/11 EXACLTLY SAME PROBLEMS WITH TE NEW FIRMWARE v1.0.2.76 Wifi drops in AP MODE / unable to use AP MODE R7800 v1.0.2.76 firmware always contains BUGS Reset the router. Still the same probl...
JayboH
Nov 12, 2020Apprentice
I've noticed several problems to .76 reported in the forum.
I noticed once I went to it, all connections, local and internet of course would drop, which has never happened in my history with this product. I rolled back to .74, and it still kept happening. I've seen it happen only once with .68, and what is weird is that .74 never used to do it either. I wonder if I should factory reset and then fresh update to .76 because something clearly has gone astray judging by all the issues listed in this and other threads.
JayboH
Nov 17, 2020Apprentice
Tried it a 2nd time after a factory reset. No dice. .76 so far in all the years I have had this router is by far the worst firmware update I've seen. ...in fact I don't recall having much problems before this.
- Richard76Nov 17, 2020TutorI also never had any problems. Decided to buy a new router... it is almost if they do this un purpose, but i am not buying a netgear router. I switch to Acer RT-AX88U as i do not trust netgear to solve this problem soon. Could have been the netgear AX8, but no thanks as for this sort of problems appears to be with a lot of netgear routers.
- JayboHNov 18, 2020Apprentice
Let us know how if you like it
- JayboHNov 26, 2020Apprentice
Ok so awhile back what I did was factory reset by holding a toothpick in the reset button for half a minute just to be extra sure. When it asks you to update to the latest firmware (.76) I said yes.
Now here's the kicker: do NOT restore your saved settings. Put them in manually one by one.
I haven't had any issues at all now. You can see my past posts that .76 was giving me lots of problems until I did this (I discussed it in several threads, not just this one.)
