AB2002
Jul 03, 2024Aspirant
Netgear R8000 AC3200 dropping device connections
Hi everyone, I'm hoping that you can help me diagnose connection issues that may be related to our Netgear R8000 router. We have been having issues with connecting to the internet for a few months n...
Jul 03, 2024Guru - Experienced User
Wireless and wired devices no connecting when this happens?
Does the Internet LED on the router turn AMBER when this happens?
How many devices are connected in total?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
AB2002
i currently don’t have any devices connected by wire. I can try that again.
No, it does not. It stays white.
16 including all smart devices in the house.
It was changed out yesterday, but I had an outage last night despite that. It says Switching Gigabit Power Supply on it, model #GP-J240-030G
Until yesterday, I had a 3ft Cat 5E 24 gauge cable. It was replaced by the provider against a new CAT 6 cable.
I set it to 2.4 GHz channel 6, 5 GHz-1 to channel 44 and 5 GHz-2 to channel 149
We have a couple D-link ethernet over powerline adapters that we use as range extenders. A D-link router is in the shop, but signal strength from it is very low where the NG router sits. The neighbour is 50 meters away and I can hardly pick up his network.
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-...
Will double check.
yes.
done many times.
no
