MathMan31415926
Apr 02, 2022Follower
Netgear R8000P: Can't reach router login page
I'm troubleshooting my mother's router, a Netgear R8000P. It was working up until yesterday, April 1st. Now, the internet connectivity over ethernet is working, but the wifi is not working. The wifi ...
nnagreg
Apr 18, 2022Apprentice
Double check you are on the same network and that your actually keying the correct router IP address.
Several times, I've made simple mistakes, thinking I was on a certain network and realized I flipped the numbers.
Hope this helps!
Within windows:
Open a command PROMPT (Type CMD)
Use the following command:
ipconfig /all
Ensure that your IP address matches the GATEWAY device:
for example: gateway 192.168.10.1 or gateway 192.168.43.11 or X.X.X.X (This is you router IP)
In the Browser: https://x.x.x.x
