Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
SimonB1979
Oct 06, 2022Star
NTP Setting are broke 🙄
6to4 tunnel is broke 🙄
address reservations are broke 🙄
did the usual reset and start afresh aswell! 🙄
absolute garbage FW as usual! 😩 worse then previous imo! 🤯
FarmerBob1
Oct 07, 2022Luminary
Use the NIST Internet Time Servers Atomic Clocks for your NTP Settings.
Are sure your ISPs IPv6 protocol is 6to4. Do they have IPv6? Who is your ISP.
What about them are "broke"?
What was your "usual" reset and restart "afresh"?
- Dark360Oct 07, 2022Star
Hi,
I updated my R8000P to this firmware last night, performed a factory reset and setup from scratch.
DNS seems to be working fine without IPv6 enabled.
Address Reservation under LAN Setup
Adding a reservation either via the table or manually you get the message below:
NTP settings were not working when I first setup, but trying again just now has worked fine.
- SimonB1979Oct 07, 2022Star
NTP setting where stuck on Data West Line and wouldn’t change regardless of how many times I clicked apply!
6tot4 tunnel doesn’t enable ipv6 when applied
Reservations fire out an invalid Mac errorall worked perfectly when I went back to .68! 👍🏻
gonna wait til My Armor sub expires and buy another brand router as the r8000p is nearly 4yrs old and the FW has been broken for 3 of them! 🤯
- FURRYe38Oct 07, 2022Guru - Experienced User
Thanks for providing more information on this.
Dark360 wrote:
Hi,
Good to hear.
Thanks for the clarification.
Are you seeing any errors after you apply the change?
What happens if you change to a different time zone or set a manual custom NTP server?
- Dark360Oct 07, 2022StarRegarding the NTP Settings.
The first couple of times I tried it reverted back to GMT-12 and default NTP Server.
It has now stayed on GMT London and Default NTP Server.
