Jmvlg
Jul 16, 2024Aspirant
Re: New - R8000 Firmware Version 1.0.4.88 Released - Hot Fix
Hi, I have v1.4.4.94; is this version older than the one you are providing on your post? I click check updates and always states it’s up to date… thanks
michaelkenward
Jul 24, 2024Guru - Experienced User
The "check for updates" feature is unreliable.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
That page will also have any software, firmware and drivers for your device, if they exist.
There is a library there of all the firmware releases for your router.
