RussF57
Dec 17, 2018Aspirant
Nighthawk AC2300 R7000 - should antennas be returned with an approved RMA?
Are the detachable antennas considered part of the router or are they considered "accessories"? I am not sure if I should pack it with the router for RMA. The instructions on the return policies page...
- Dec 17, 2018
Greetings,
The antennas are not considered accessories. You typically keep everything except the router and antennas, even if they can be detached.
shadowsports
Dec 17, 2018Hero
Greetings,
- RussF57Dec 18, 2018Aspirant
Thanks for your help !
Russ
