stottad87
May 22, 2017Aspirant
nighthawk r6700v2 losing internet connection periodically
Periodically i will lose internet connection to the router. when the pc is plugged directly to the modem theres is no issue. but whenever i lose connection through the router i turn the router off, u...
- Mar 29, 2018
Hi Mkoish and Bob_Ross,
Please check this firmware and see if the same problem.
https://kb.netgear.com/000054437/R6700v2-Firmware-Version-1-2-0-16
ElaineM
Jun 02, 2017NETGEAR Employee Retired
Did you follow the steps in doing MAC cloning?
If that didn't work, try the article below.
I cannot access the Internet with my NETGEAR router; what troubleshooting steps should I follow?
MargaretB
Jun 02, 2017Aspirant
I too have this problem. I am using a Comcast Cisco cable modem. I have two Win 10 PCs connected by ehternet ( these share a single cable to the router as I use a simple non wifi router) Previously to installing the Netgear router, I used this setup successfully with a Medialink wifi router but the ethernet was limited to 100mbs. Now, I have to power off/on the Netgear at least once a day as it loses internet connection. I tried the MAC spooling but that stopped all internet access so I reset the MAC setting in the router admin dialog to Use Default. I updated the firmware to the latest un installation of the Netgear last week.
