stevedude's avatar
stevedude
Nighthawk R7000 won't recognize network devices connected through switches
Nighthawk R7000 Windows 10 Pro latest firmware update on 3/22/2019  V1.0.9.64_10.2.64 Router recognizes about half of my network.  Doesn't recognize switches or devices that would be connected t...
  • stevedude's avatar
    stevedude
    Jun 01, 2019
    Solved.  Got a buddy to help me sort it out.  The internet provider company had installed not just a gateway to the fiber optic system but a modem router combo as well.  I told them that the router part needed to be off as I was using my own.  They may or may not have done so but their piece of equipiment was still setting up its own subnet which is where the non-recognition problem lay.   Removing that piece of equipment and hooking my router directly to their "gateway" {their term}, which apparently functions as a modem even though they don't call it that, fixed all my problems.
