jnt2112's avatar
jnt2112
Nighthawk R7000
I can connect to internet directly by ethernet cable but absolutely nothing will connect thru wifi. It always says incorrect password even though I have done a reset twice and also tried changing the...
  • JamesGL's avatar
    JamesGL
    Aug 13, 2017
    Hi treball,
    It is how NETGEAR routers work. It should be connected to the modem for Internet to work.
