AJTheo
Dec 07, 2021Aspirant
Nighthawk R7100LG Disconnects Hourly
Hello, I have the R7100LG and have the following issue. ISSUE: The internet connection interrupts for 2 seconds then reconnects *every hour exactly*. As a result I am kicked from online service...
Dec 07, 2021Guru - Experienced User
The router isn't connected to any other modems is it? Just using the SIM card?
Any other wifi broadcast devices near by?
FYI, Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
AJTheo
Hi,
Nope its just using the SIM card.
No other wifi neighbours or devices that broadcast wifi nearby, out in the countryside so 4G is the only option.
Thanks for the link to the forum I'll post there too to see if anyone knows of any solution.
Cheers
AJ
- FURRYe38Dec 07, 2021Guru - Experienced User
đ
