Muzz1986's avatar
Muzz1986
Nighthawk x6 r8000 POE
Hi Can anyone tell me if the nighthawk x6 has POE compatibility I’m trying to add two ip security cameras but can’t seem to get them to work. Any help would be appreciated thanks.
  • myersw's avatar
    myersw
    Oct 16, 2019
    No consumer grade that I know of. Need to get a switch that supports PoE. Not sure how much they cost. My Ubiqui Unifi swithes that do PoE cost over $100, but they are smart switches. Can be configured.
