Bigler78
Aug 24, 2022Aspirant
Nighthawk X6 r8000 slow wired connections
I upgraded my internet from 100 Mbps to 500 Mbps today and have been able to consistently get wifi speeds over 500 Mbps. My wired devices all get less than 200 Mbps. I replaced all my cables with cat ...
- Aug 25, 2022
The xbox is a little harder (since you figured out the roku).
I've seen numerous posts on here about xbox's not hitting full speed when ran through a router but will when ran directly through the modem. Not sure if its how microsoft has their backend setup as even with the xbox entered into the routers DMZ (automatically forwards all data in basic terms), you still get the lower speeds. But 200mbps should still do everything you need. Streaming 4k only takes 25-40mbps and gaming itself doesn't use much data. It just slows you down a little for downloading games but even that isn't much as its still 200mbps.
Aug 25, 2022Guru - Experienced User
Bigler78
Aug 25, 2022Aspirant
I agree - thank you for your time and thoughts. Much appreciated!
