DS_2018's avatar
DS_2018
Nighthawk X6 R8000 versus X6S R8000P
I just purchased the Nighthawk X6 R8000, the store I purchased the router from did not have the X6S R8000P.  Home networking is not my specialty, so I'm wondering if I should return the X6 R8000 in e...
  • JamesGL's avatar
    Jan 18, 2018
    Hi DS_2018,
    Here are some features that R8000P has which R8000 does not have.
    • Processor is 1.8Ghz compared to 1Ghz of R8000.
    • It has port aggregation which combines two Gigabit Ethernet ports to improve the aggregated file transfer speed(Given if you have devices that uses Link aggregation like NAS).
    • MU-MIMO support.
    • Memory is 128MB flash and 512MB RAM compared to 128MB flash and 256MB RAM.
    • Wireless is Upto 4GHz speed distributed to 2.4Ghz and 2(5GHz).
