Imperialsalsa
Aug 07, 2023Aspirant
Nighthawk x6 r8000 Wifi issue
I have a Nighthawk x6 r8000. Firmware is up to date. Using starlink. Wifi is showing off in the netgear router menu but the physical lights on the router are lit up. I have reset the router I have...
Imperialsalsa
Aug 09, 2023Aspirant
Yes
DexterJB
Aug 13, 2023NETGEAR Moderator
Hi Imperialsalsa , if you're still experiencing the issue. We recommend that you reach out to our support team via the link below if you need any technical assistance with your NETGEAR device.
https://www.netgear.com/about/contact-us/
You can also call the number below.
1-888-NETGEAR (1-888-6384327)
Dexter
NETGEAR Team
