fxv300
Jan 18, 2021Aspirant
No internet access
Occasional dropouts with "No internet".....good signal in location, a router reboot usually fixes. Just found new firmware Current Firmware Version 1.0.2.64 New Firmware Version 1.0.2.82 Ha...
Jan 18, 2021Guru - Experienced User
I'm on the .82 without issues.
What modem/gateway is it connected to?
When it drops, is it all devices? just wireless devices? Wired devices?
fxv300
Jan 19, 2021Aspirant
Problem is happening to many devices, but randomly. Yesterday had the issue with a laptop located in the same location which worked the day before. Rebooted RAX20 and it worked fine afterwards. Gateway is via a Virgin Media Hub3 setup in modem mode. When that happened about 16 devices were working fine in the rest of the house. I will update firmware and see what happens. This problem was happening much more frequently previously on the 5G WiFi.
I will probably setup the devices with a "assigned IP address".
Thanks for the feedback.
