rudiklein
Dec 17, 2017Star
No more 2.4 Wifi on R7000 Nighthawk after V1.0.9.14_1.2.25 update
Hi, Never had an issue before with the R7000, but after the V1.0.9.14_1.2.25 update I have no wireless 2.4Ghz devices connected to the router. 5Ghz works fine, but most of my devices do not suppo...
- Dec 18, 2017
rudiklein wrote:
But honestly, a factory reset sounds like an advice from Microsoft on Windows.
Yes, it does, but it's well documented on this forum that certain firmware updates are incompatible with the settings from previous versions. Chalk it up to Netgear's unwillingness to fix their configuration subsystem to be backwards and forwards compatible.
JamesGL
Dec 18, 2017NETGEAR Employee Retired
Hi All,
I have verified it from our engineers that the latest firmware includes the fix for wireless connectivity issue.
candroulakis
Dec 18, 2017Aspirant
I'm certainly not installing any update yet until I hear from multiple people it fixes both the loss of wifi and the speed loss encountered in the 5GZ range.
